RCU Forums - View Single Post - CARF-Models Mig 17 build thread
Thread
04-01-2022 | 06:08 PM
73
Airforce7
My Feedback: (
31
Feb 2004
1,125
Brentwood, CA
Airbrakes complete
This took a little longer than I thought it would but managed to get the airbrakes installed. A lot happened during this portion of the build, but here's a short summary:
Built up the mounting blocks provided in the kit, lightly sanded the openings to get my servos to fit
Sanded the base block to follow the shape of the fuse to maximize contact area for gluing
Built up the push rods which came out to about 60cm in length
My servo arm hole spacing for push rod attachment was a little off by a couple of mm (33mm vs 35mm per CARF recommendation)
Prior to gluing the blocks down, I used double stick tape to check position and alignment with the airbrake horn
The push rod length and servo arm position dictated the point where the blocks were to mount to the fuse, I drew an outline of the block with a pencil on the fuse to help aid in the gluing process
I glued the blocks to the fuse one at a time so that I could rotate the fuse 90 degrees down to make it easy to align and add weight to the top of the assembly while glue dried
Once everything was dry, I check servo arm travel and discovered I had some binding between the airbrake and fuse outline for the airbrake in a specific corner (see picture with red circle)
I had to sand the inside of the airbrake and the fuse outline a bit to smooth out the airbrake deployment
After sanding and touchup paint added I checked the operation with the transmitter, and all looked good
Mounting block parts (glued)
Mounting block with servo (test fit)
Mounting block parts (bottom view)
View with bolts assembled
Bottom view showing blots
Misc shot of servos with brackets
Airbrake closed position
Airbrake 45 degree position
Airbrake fully open
Push rod detail
Push rod length
Fuse preparation for gluing
Curved block to match the fuse shape
Completed servo and airbrake installation
Binding in this area, both sides (taken after sanding and touchup paint)
Close up of the binding area
Reply
Like
Airforce7
View Public Profile
Send a private message to Airforce7
Find More Posts by Airforce7
View iTrader Profile
