RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 11-12-2003 | 04:11 PM
aero nut
Default RE: gas fuel with glo plug no ignition
Thanks everybody for all the input I am receiving, it is a lot of fun and educational at the same time, the next step on this project will be trying
the methanol:gasoline blend in a perhaps 10 to 20 percent range also I will try to get some Amsoil I heard that it works real good even on a 100:1
mix ratio which it means less contents of oil, cleaner buring more power, switch to a four stroke plug and see what happens.
Iwill also be thinkering with avgas and the pure methanol version, I am convinced that we can do something to improve this and saves us some weight and MONEY.
I would like for some of you guys to try this configuration so we can compare results and get to some conclusions, this would be a lot of fun and interesting.
Thanks. Bill Pomplun.
P.S. By the way my club is located in Tijuana Baja California Mexico so once again you can say that R/C modeling is UNIVERSAL.
