The plane will tend to dive a little in the turn if you just use aileron. So you will need to use the elevator too. You can "bank and yank" using aileron and elevator but, the turn is smoother if you perform a coordinated turn using Rudder, elevator, and aileron together. On your sim you can try it. Give a little bit each complete the turn and then use just aileron and elevator on the next turn to see the difference. If you desire to fly scale planes like warbirds coordinated turns are a must since those models will have a lot of roll coupling.
