RCU Forums - View Single Post - CARF-Models Mig 17 build thread
Thread
04-08-2022 | 01:48 PM
74
Airforce7
My Feedback: (
31
Feb 2004
1,125
Brentwood, CA
Main gear and door work
Pulled out the wings and began work on dressing up the doors, wheels, and tubes. One of the things I noticed right away when I first started handling the wings was how heavy they felt. So, I weighed them and each wing without the servos is ~8.4lbs. Started with painted the inside gear doors white. Needed to disassemble all the doors, which was not too hard. On mine the stock wheel rims and hubs come all silver, so I painted it to match the full scale. I'm reluctant to paint the struts white at this time as I didn't want to screwup the alignment from the factory and brake wire routing, plus there are a lot of set screws around the retract unit. Maybe after some successful flights I will revisit painting them. Added a little white on each of the wing tip tubes as well (left one for counterbalance while the right one a functional pitot like the full scale). Plan to start work on installing the servos next.
Stock main gear assembly
Stock main gear - outside view
Stock main wheel and strut w/o door covers
Gear door - painted
Strut support rod
Strut with wheel removed
Main wheel with brake disk - painted (outside view)
Main wheel - painted (inside view)
10mm nut driver
Close up - left main
Close up - installed strut support rod
Both main gear deployed
Wing detail
Right aileron and note
Pitot tube - right wing
01:49 PM
. Reason: minor text edit
Reply
Like
jcterrettaz
(04-08-2022)
Airforce7
View Public Profile
Send a private message to Airforce7
Find More Posts by Airforce7
View iTrader Profile
