I finally got around to running up the motor and seeing the wattage. With a 13x6 wood prop I'm at about 423 watts at WOT which will be just perfect. Manufacturer claims it'll go to 543 but I figure 120 under is a good safety margin. That prop does push my ground clearance a bit tight so I might drop down to a 12x8 and test that.
