RCU Forums - View Single Post - Need engine help
Old 11-12-2003 | 07:56 PM
wisdom-seeker
Default RE: Need engine help
I've always found that the best way to adjust the fuel mixture on the ground is
to rich it up at full throttle until the engine four-cycles, then lean it out to
the point where the four-cycling just stops. That, in the air, the fuel mixture
is just lean enough to run correctly.
