This Roo rebuild is near complete, is missing the UAT ( have no clue where it may be
) I got one on the way to be here next week, the batts are in the batt packets behind the CG, I will be making a couple of extentions, I'm going to use 1 LIFE and 1 LIPO, CG is slightly back from 95mm, with a full UAT it will come to balance right at 95mm, no lead added this time + with the remaining fuel after each flight, 1/4 to 20% of the tank, the CG will definitely be on target this time around, no need for the 1 1/2 lbs of lead in the rear of the fuse that I had to use before.
