ESC's are spec'd to be rated slightly higher than the motor/prop combination can deliver, so with an ARF like that where they pick the esc/motor/prop combo you're usually safe, but if you were to start tinkering with prop size it would be possible to over-amp or over heat a component.
Reason: removed stupid answer
