No improvement, also notice sensitive on elevator at low speed with flaps out.
Start to question if my CG position is correct.
i have CG at 7" from leading edge at fuselage side ( witch actually is at frame #6 where wing dowel is ) gears in, empty fuel tank and full bubble trap. correct me if im wrong.
can try to move cg 6 3/4" just to confirm ?? will be needed some 200grams more in front.
