RCU Forums - View Single Post - C of G Help!
Thread: C of G Help!
Old 05-17-2022 | 12:53 PM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Originally Posted by thundertiger76
So I wanted to try the Spitfire out today but I couldn't find anymore weight except for 100g more to add to the nose and I went with that.
So with 775g of lead to the nose in total at about 120mm from the leading edge and it seem to fly well although I had to trim a fair bit of up elevator in so perhaps it's still a little bit too heavy on the nose?
Maybe. It’s difficult to determine CG location based off trim without first knowing your wing and stab incidences are. Example, if your stab is at zero incidence and your wing is between zero to 2 degrees positive, then I would agree that your CG is a bit forward. If your stab has some positive incidence then the up trim could be to compensate for that. Another tell would be the landing. A nose heavy airplane will want to land fast and require lots of up elevator.
