RCU Forums - View Single Post - C of G Help!
Thread: C of G Help!
Old 05-18-2022 | 03:58 AM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
The easy way is to block up the tail until you get the same measurements for the leading and trailing edges. Then check to see if the propeller is 90 degrees to the table surface. Then measure the distance from the table surface to the leading edge and trailing edge of the wing. Post the measurements and we cab go from there.
thundertiger76 (05-18-2022)
