RCU Forums - View Single Post - JP hobby elec brake question
Old 05-19-2022 | 05:38 AM
Agrav8ed
Originally Posted by invertmast
based off your pictures of the bigwheel brakes, the lack of breaking is because of the lack of surface area between the wheel pads and the brake drum.
if you were to fill in the area on the brake drums between the metal area’s with an epoxy so as the entire drum surface is flat, i bet the breaking action would improve greatly. If you could find some sort of thin break liner (maybe some DIY gasket maker material or flat O-ring) you could probly make them work amazingly well.
That's a pretty good idea to increase the surface area at the magnet side. I have the some L39 jet and use a Xicoy Lg 15 controller for the brakes and retracts. I have not issues with mine. However, I only fly off of grass.
Tone
SAP_2000 (05-19-2022)
