RE: ? before breaking in new fantom .18
Thats the temp I broke in my NTC3. The tip I should say is while your truck is in the house, do all the stuff like fill the tank, prime it and all those steps. Then put on the glow starter (ignor that if you got the ez-start system) and run outside into your garage and try to get it started as quickly as possible. It is so hard to start a cold engine so work fast! If it takes too long and your engines turned cold, go back inside and let the engine warm up again and repeat those stups.
