RCU Forums - View Single Post - CARF-Models Mig 17 build thread
Old 06-09-2022 | 09:50 PM
  #113
Airforce7's Avatar
Airforce7
My Feedback: (31)
Default Nav tail and pass through holes
Managed to get the nav light installed in the tail. After some sanding I realized it wasn’t going to fit. In order to save as much material as possible surrounding the nav light assembly I had to file grooves in the aluminum to accommodate the red and black wires. Worked out perfectly. Also I used an extension rod with a drill bit on the end in order to drill a pass through hole into the fin. This will allow the wires to make it inside the fin and on to the exit at the fuselage for connection. Lastly I drilled the pass through holes on either side of the fin for the elevator servo leads. I did run into some wood and hysol in that area so be careful when you make the openings.
Nav light assembly with grooves
Nav light with tucked wires
Nav light fully inserted
Extension rod with drill bit
Extension rod with drill bit showing required depth
Elevator servo lead hole
