RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 06-14-2022 | 12:47 PM
1967brutus
Originally Posted by cmulder
On that regulator mount a tiny magnet on the lever and then measure its movements with a hall sensor.
Then you can open the solenoid synchronized with the fuel demand of the engine.
Would that work and help?
I don't think you can "sync" the solenoid with the regulator movement, because when the solenoid is closed, the regulator won't move.
But it MIGHT be usable (provided accuracy of the hall sensor allows it) to derive some sort of flow measurement out of that signal which either could be used for R&D, or possibly as a cascade control for fuel feed. I'd have to think about that.
But as it is, I'd say that cascade control simply is way too complicated.for our purpose.
