RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 06-14-2022 | 02:30 PM
1967brutus
Originally Posted by cmulder
This is the buton (norvell) style glow plug adaptor but it does look promising.
The controll unit / and cdi / battery will be way to heavy to fly but be among the smallest ignition engines "out there"
anyway back to the original subject
That really is not too far fetched... I am working on a 1/2A project on gas, using an OS FP 10. Ignition weighs 40 grammes (Runtronic) and the single battery set-up will consist of a 2S 400 mAh LiPo. Won't provide much operational time, but I expect somewhere in the neighbourhood of 30 minutes.
Now for that Cox engine, I am not really sure if the ball and socket would hold out on my standard 10:1 fuel/oil mix, but other than that, I am 100% positive that with a Runtronic ignition I can build something flyable, RC, with that engine. Not even really going to be a challenge. Won't be an exiting hotrodder, just a nice sport plane, but still, 100% sure it WILL fly as long as the engine doesn't wear out
But it will need something different than just a Norvel style glow plug adapter because the spark plug will really mess up the shape of the combustion chamber big time and that will kill a lot of power. Would not be surprised if that would need a custom made sparkplug,
The FP10 however, as you can see, runs fairly well, and that is still without the solenoid.
