RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 06-15-2022 | 10:14 AM
  #40
1967brutus
Originally Posted by cmulder
https://www.technirub.nl/rubber-tril...r-type-b.html\
The cheapest localy is about €4 each...
Love this way of mounting engines besides less noice it also reduces/ avoids damage during poor landings. Also less weight then a nylon motor mount.
Il ask them if they ship international
Oh my, that indeed is pretty expensive... If they don't ship international, let me know. You'll need to have a bit of patience, but in case needed, I can order, say, 20 pieces or so and send them to you.
But I would not know why they wouldn't ship int'l...
They also have small o rings l have to measure what are used on needle valves and the fuel filler valves that started to leak air.
What material is best for our use?
For methanol NBR is OK, all applications.
For gasoline, Viton is the better choice.if the seal has to allow movement (like needle valves). For static seals NBR suffices.
cmulder (06-15-2022)
