RCU Forums - View Single Post - Finishing epoxy question
Old 06-18-2022 | 10:32 PM
Dave Wilshere
John
If you sand through the same area each time I guess it’s higher than the surrounding area. Generally if you go through in spots you just use resin to seal that area again. You are looking for a uniform surface level.
Adding in cloth will never work as you can’t feather the edges, can you post pictures?
Dave
