So due to time, weather and circumstance I finally got my new L39 into the air. I have to tell you, man I love this jet. I forgot how smooth and easily it flies and yet how agile it can be at the same time. It really is a great flyer. And low passes with the smoke on just look incredible. I forgot how much fun it is. I also forgot how much fuel I can burn through in a day lol, especially at these prices. On my original L39 I would have a bit of an issue with the nose gear door not closing unless I am straight and level on take off. So when I built this one I changed the servo geometry for the nose gear door and reinforced the vertical plates. Problem solved. However, on this jet, I had a problem with the right main door not closing all the way. Initially I thought this may be a geometry issue also but now I just think it may be the servo as it did not feel very smooth when I cycled it by hand. I will play with it and see. I did not really have any issues with the brakes but I am using a LG15 controller and as I flew on grass it is a bit easier to stop. Anyone on the fence for a large L39 should strongly give this one some consideration.
Tone
