RE: Why can't I fly?
Sorry, won't take off in the grass. I think the kit was $39 or $44, is pretty complete. Just add the Rx and servos. If you build this, add a wood piece behind the LG wire to keep it from digging into the foam on landing. Also come up with a better way to mount the tail wheel. It is easy to knock loose. If you have some experience, it should go together in three evenings. I like to mess around with the details, so it takes me a bit longer. You can make your own custom decals by printing the designs on clear shipping labels. Make sure it is clear and not opaque. You will get much better color saturation if you print over the design two or three times. Attached is a photo of a GWS Mustang the I did from an unpainted kit.
