RE: How do I install this kill switch?
check it with a continuity / ohm meter. You want it set up with an open circuit when the engine is to run. YOu want the internal connection of the switch closed (conducting current) when you want the engine not running (kill position). No test meter connect any thing to it and see which position conducts current.
