hey guys, as you most likely know the glue on World Models covering is nothing great and it is not applied evenly. well I am testing that Felt & Foam Tacky glue. to thin it out I tested it with mixing it with Rubbing Alcohol and with Denatured Alcohol.
it didn't mix well with rubbing alcohol, but it did mix and thin-out well with the denatured alcohol. I am only testing it with popsicle sticks. if it hardens well and is strong enough, I will test it on the covering. but the real test would be in the sun at the field, that is knowing that if the glue gets too hot it can become soft. anyway it's worth a try.
Jim
