RCU Forums - View Single Post - Turbine Conversion Of 80mm Freewing A-10 To Single X-45 Turbine
Old 07-05-2022 | 05:50 AM
Viper1GJ's Avatar
Viper1GJ
My Feedback: (20)
Removing foam for turbine mounts
Making turbine cut out pattern on card stock
Turbine cut out shape transferred to card stock
Turbine template taped to aft fuse
Pattern transferred to foam
Foam removal started with knife
I was concerned about the thickness of foam remaining after fitting turbine in the fuse but I think it turned out OK
Foam nibbled out with hot wire cutter...
...and flush cut saw
I removed little by little trying to avoid a big mistake in cutting away the foam
Turbine cavity in aft fuse
Test fit seems OK
