RCU Forums - View Single Post - Turbine Conversion Of 80mm Freewing A-10 To Single X-45 Turbine
Old 07-05-2022 | 06:04 AM
Viper1GJ's Avatar
Viper1GJ
My Feedback: (20)
Installing turbine mounts
I used my laser level to project the thrust line down inside the area where the foam was removed
The laser when aligned with the marked lines allowed the thrust line to be accurately transferred to the fuse sides
1/8" plywood plates positioned 1/8" below thrust line and glued to foam with E6000 and allowed to dry
Setting the depth of cut for the turbine mount slots
Foam slot cutting technique is from Paul A's videos
Ready to melt foam slot
It took about 4 to 5 reheats to cut and smooth out the slot
Turbine mount test fits.
Slot cutting technique workd great
NIce and tight fit
I was pleased with results
