Installing turbine mounts
This is Paul's technique for centering and cutting the turbine mounts. Measure the distance between the turbine bracket bolts
Transfer this distance to a card stock template that will fit in the turbine cavity
Align the template with the centerline of the fuse
Mark the edges of the template on the turbine mounts
Turbine mounts marked and ready to cut
Mounts cut and glued in with E6000
Clamp in a plywood bridge to keep the mounts square and let it dry
