Cutting the pipe channel
I started out trying to sand the cavity with the 3d printed mandrel and 80 grit paper but quickly looked for a faster way. I formed a copper wire around the mandrel
I sized the wire around the outer pipe
Turns out it was about 2.25" in diameter
I formed the wire to fit in the hot wire cutter and it immediately fried the cutter.
I then mounted it to my soldering gun and it got hot enough to cut the foam... but slowly
I rigged a quick depth of cut guide
Then cut the channel freehand following lines drawn on the foam
It wasn't perfect but was good enough
I used the mandrel to clean up the channel
First test fit was good
The pipe exit hole was pretty bad and would have to be cleaned up
