Preparing for carbon tow carry under spars
1/16" ply spar formers were fabricated
Spar formers marked and ready to cut
Dry fit of spar formers after cutting
Bottom view of spar formers with pipe channel cut out
Balsa separators dry fit to keep the formers square
Spar formers glued in with thickened epoxy
Epoxy cured
Pipe channel sanded smooth and high spots removed with sanding mandrel and 80 grit paper
Finished spar formers
