RCU Forums - View Single Post - Turbine Conversion Of 80mm Freewing A-10 To Single X-45 Turbine
Old 07-05-2022 | 08:00 AM
Viper1GJ's Avatar
Viper1GJ
My Feedback: (20)
Carbon tow spars fabricated
Card stock paper glued on top of spar formers with CA to seal the gap between them
Card stock gap seal view from bottom show channel between spar formers to lay in carbon tow
Area taped off to keep epoxy off surfaces
Stab carbon spar tubes scratched and scuffed with Perma Grit file to get good bond of carbon tow
Popsicle stick stuffing tool made to stuff carbon tow down into spar channel
19 long strips of carbon tow wetted out on wax paper and stuffed into each channel of front and rear stab spars. The scientific number of 19 was because that's how many I got laid out on the first strip of wax paper, so I just did it again for the other spar!
Next 4 short strips were wetted out for each spar. Turns out it was a good guess since it filled the channel up in the center
Paper towel squares stuffed in the channels to absorb excess epoxy
Finished layup of both spars
Peel ply strip placed over the spar layups and tape added to keep it flat
Layup cured and tape removed
View from top after cure
Foam plugs replaced in front and aft of stab
Foam filler applied and sanded and new Promodler HV elevator servos dry fit
