Fabricating and fitting rear pipe exit from fiberglass parts
Here is the bottom tail cone after the freehand pipe channel hot wire cuts. Not pretty and I had failed to make the fiberglass part on step one above.
I put a wood spreader between the sides so they would not pull together and used vinyl tape to make the bottom fuse mold shape
Same steps as described in step one above, wax, 2 layers glass, pattern cut and applied
Glass wrapped around mold
Epoxy cured
Tape removed and parts in place for marking
Trim tape used to lay out cut lines
Ready for cutting
Top piece cut and placed over bottom piece
Pipe exit hole marked
Pipe exit hole on bottom marked
Cutting top piece
Bottom piece marked and ready for cut
Bottom piece cut and pipe dry fit test
Pipe dry fit test from top
