RCU Forums - View Single Post - Turbine Conversion Of 80mm Freewing A-10 To Single X-45 Turbine
Old 07-05-2022 | 12:57 PM
Viper1GJ's Avatar
Viper1GJ
My Feedback: (20)
Gutting front fuse
With most of the rear fuse complete the rear fuse halves were glued back together and I turned to the front fuse
Started removing foam for a fuel tank placed on the CG with a hack saw blade
The first cuts were pretty easy
The long center section removed
A Dremel oscillating saw used to remove the plastic front hatch mounts
Next I used an old foam wing spar cutter taped to a stick to hot wire cut the foam from each fuse side
Results came out pretty good. View from the cockpit hatch
View from the rear of the front fuse section
Rear of front fuse. Still some foam left here for good structure
