RCU Forums - View Single Post - Turbine Conversion Of 80mm Freewing A-10 To Single X-45 Turbine
Old 07-05-2022 | 01:26 PM
Viper1GJ's Avatar
Viper1GJ
My Feedback: (20)
Fuel tank mock up
Initial measurements showed a 70mm x 80mm 320mm fuel tank would fit right over the CG. I made one and discovered it would not through the cockpit hatch so made the mock up 70mm x 70mm x 320mm and it worked OK
Test fit through cockpit hatch
Tank fit right over CG which is basically the front wing spar
View from aft of front fuse
Approximate location beside fuse. Tank is centered on front wing tube. Initial estimate was for approximately 1.4L or about 46 oz which is plenty for the X-45.
