RCU Forums - View Single Post - Turbine Conversion Of 80mm Freewing A-10 To Single X-45 Turbine
Old 07-05-2022 | 05:23 PM
Viper1GJ's Avatar
Viper1GJ
My Feedback: (20)
Pipe mounting
Some final adjustments made with drum sander to allow pipe to be installed from turbine hatch with bell mounted
A small radius needed to allow pipe to slip in the tail
Four plywood pipe standoffs taped in place
Stand off positions marked on top and bottom
Standoff epoxied in place
Front ends beveled to allow pipe to slip in easier
Standoff cured ready for trimming
Standoff marked and trimmed with sanding drum
Bottom fiberglass part dry fit
Bottom fiberglass shell epoxied in place
Top fiberglass shell epoxied in place
Tape removed
The gap between the bottom foam parts was filled with thick epoxy and two layers of fiberglass cloth to give it strength
Primer applied
Foam filler applied and sanded. 3 more coats of primer applied and sanded. Primer applied to aft end of pipe.
Came out ok
The following 2 users liked this post by Viper1GJ:
Halcyon66 (07-05-2022), Sparhawk (07-05-2022)
