RCU Forums - View Single Post - How do I install this kill switch?
Old 11-13-2003 | 12:39 AM
Antique's Avatar
Antique
Default RE: How do I install this kill switch?
There are no in line connections on a G38 coil..There is a small black wire on the front of the coil..Solder a wire to it and the other end to one side of the switch..the other side of the switch goes to ground..When you close the switch the engine will stop...
