RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 07-15-2022 | 12:04 PM
  #161
1967brutus
Originally Posted by cmulder
Is there a requirement on the location of this restriction in the fuel flow?
Could it be as simple as a plug in a fuel line with a small hole drilled in it?
In theory, not, but in reality, gasoline being a volatile fuel, the restriction should be the last in line to prevent bubbles forming due to the low pressure area, and for the same reason, the solenoid should be as close as practically possible to the restriction. It is not a big difference, but it IS noticable.
