Originally Posted by
1967brutus
In theory, not, but in reality, gasoline being a volatile fuel, the restriction should be the last in line to prevent bubbles forming due to the low pressure area, and for the same reason, the solenoid should be as close as practically possible to the restriction. It is not a big difference, but it IS noticable.
What if there is a small plastic disk under the fuel nipple of the solenoid casing with the hole in it?
Also in setups where the solenoid is external from the carb just plugging the hole where the needle holder used to be might work too.
Then just use the original fuel nipple and possbly install the restriction disk under that.
Not having a needle stick out will make the carb much less vulnerable to crash damage like the os la series of engines.
On the other hand the simplicety of just mounting it on the needle holder also has advantages in other situations
