Originally Posted by
1967brutus
??? No? I want one cylinder firing at a time. Hence the remark to check the camshafts to see if (for example) 1A and 2B are NOT in the same phase. If that is the case, then all the other cylinders will also be in the right sequence.
Right, with the sensors 90 to each other, and the magnets at 180. what was the reference to the "big bang" setup you mentioned earlier, I thought you were going for the exhaust sound from two cylinders firing simultaneously.
