RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 07-18-2022 | 09:09 AM
  #197
1967brutus
Originally Posted by cmulder
Another thought.
There are these hall sensors that can measure rotation. One use is in the sticks of our transmitters,
What if you stick a magnet on a output shaft and then you know exacly what position the crankshaft is at.
Feed that data in some proccsing unit like used in the solenoid system and then have a (or several) output that commands a coil to fire.
Then you can adjust the timing of each coil in software (rpm based?)or even remote. Things like rpm telemetry are then also possible.
Yeah... but way to complicated for me to execute. Not going that route if I can buy a set of ready made ignitions...
