Originally Posted by
voyager_663rd
igniter tested at 1.3 but hey, that's just on a tester. I've put it back on the charger for longer as it's also 3300mah so it may take longer. All is put back together (no RTV at this stage) so we'll try again tomorrow.
Thanks for the insight
If it's NiCad/NiMh, it appears to be charged enough, even if not at full capacity. So you should get a glow....Check in reduced lighting - can be hard to see in full sun.
