Originally Posted by
Tip22v
the middle pin is not used, the two outside pins are neg and pos. Which way you plug them in is dependent on the config of your retract motors, you plug them in so that your retracts all move in the same direction when activated. Brake polarity does not matter. Hope this helps
. Tom
Tom, thank you! I took a regular servo extension and swapped the signal and positive wire. I am assuming this should work?
