RCU Forums - View Single Post - Spektrum Powersafe receiver / AS3x module on large jets
Old 07-21-2022 | 02:22 PM
F900
I'll give you my 1c of thoughts, 90% of all my jets have the Spektrum Power receiver with the AS3000 gyro, BVM L-39, Rafale, Bandit x 2, F-18, F1 and CARF Flash and other jets I've owned and I have had no issues. The only issue I have had with some is when you switch on the RX the gyro does not activate, you just have to disconnect the gyro, reconnect and issue is solved. I also have Cortex gyros, I have one in a BVM UB Evo and honestly I can't tell the difference in the air. AS3000 has worked for me, simple to use and set up.
