The pico pi uses the same processor so the code should be close but I would expect the timer configuration section at the top of the code would require a bit of tweaking because of the different board wiring. Nothing more than a few minutes of work. Why did you want to switch boards?
Originally Posted by
cmulder
This might be "old news" but just found out that the arduino ide supports the pico pi microcontroller.
Does this mean that the code should work ? (after recompiling)
Got 2 "standard" pico's on the way and a 3rd with the wifi module to learn/ play with.
