Originally Posted by
Eastflight
Just a point to note please, when I have done the first few turns on the liner in a cyclic sweep should I then turn the liner over and do the same on the other end in order to make a cross hatch pattern or just corkscrew in one direction
Its my first time honing..!!
First make a clockwise sweep while going down in the cylinder with the hone or emery, then make a counterclockwise sweep. Repeat alternate until you have the whole liner covered in the cross hatch pattern.
If you've never done it before, take a random piece of pipe of comparable diameter and length, and practise a bit. Its a simple movement, you'll get the hang of it soon enough.
