RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 08-08-2022 | 08:21 AM
  #307
Raleighcopter's Avatar
Raleighcopter
that is the plan. i modeled that protrusion to be hollow. the magnum 30 only has a 7mm space for the strap and the prop hub is also only about 7mm thick. the plan is to eventually share a parametric design where a user could simply change a couple dimensions and have a working bracket for many different engines.
Originally Posted by John_M_
That's not bad Raleighli' ... I take it the hall sensor will fit in a recess where the rectangle protrusion is, from behind of course.
