Looks good Dave - Upgraded model from mine..
Was the dual Z an option or did it come stock with that?
I can see you have the Creaity glass bed I think - That "sticky" side works well for PLA (for a while) but when you get to ABS/ASA temps it will Magically stop working (forever). The cure is to flip it over and print on the glass - Using a "sticky goo" as mentioned. Glue stick works great for PLA.. My goto for ABS is a mix of white glue, icing sugar and water. Odd mix but works well - I will find the data for you.
