RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 08-16-2022 | 01:45 PM
  #391
Glowgeek
Originally Posted by John_M_
You'll be ok with a reference mark... you said the 1/4-32 time-sert OD is too small for the existing 5/16-32 threaded hole correct.
Correct.
Yes, an index mark on the tap and a light tap or two to set the tap so it bites straight away upon rotation should get the job done. May take a couple of attempts.
I found a club member with a 4" or 5" benchtop lathe. I'm sure it's good enough for this type of light work. I'd have one myself but need one so infrequently I can't justify the cost. I suppose if I had one I could create projects but have little interest in metal working. I do enjoy woodworking however and have a nice cabinet shop.
