Originally Posted by
Raleighcopter
i got all of you beat. ever seen the movie Maraton Man? i had a root canal done by a (no longer licensed) dentist on my front tooth (#8) with an active abcess and you may know that the general anesthetic does not work at all in an acid environment which an abscess is. i have never in my life experienced such pain. anyway, hope you feel better lonnie.
by the way, i've been playing with fusion and here's the ring for the magnum .30. any thoughts on whether or not the abs will hold the M2.5 threads?
WOW!!!! Thats a bad one!!
ABS should hold M2.5 well - 2.3mm hole in CAD (seems big but the Squeeze out makes it right. and just start the threads with a tap - let the bolt make the rest If you can make the threads "long enough" and make the bolt form the threads it should be good - maybe block out the threaded end to get more thread coverage - might take a few tries.
Structural like this should be printed "solid" at higher end of temps and slow for best strength.
