RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 08-24-2022 | 01:03 PM
  #532
Glowgeek
Originally Posted by Raleighcopter
Are the two cylinders supposed to have different valve dwell times?
The valve opening duration may be different between cylinders, not sure, haven't measured it. The lobe separation angles do have to be different between cylinders on twins however. I'm not 100% sure why but have heard it's because the cams spin opposite directions and the intake and exhaust ports are on opposite sides. Still makes no sense to me explained that way. But then, I can be about as sharp as a basketball at times.
