starting
It goes into the groove on the flywheel and around a groove on the starter cone of a electric starter on the other side.
Then you are supposed to hold the starter up and press the boat down to get enough belt tension so it does not slip.
Once the engine is running tuck it away from moving parts like under the engine.
Older generations helicopters like the shuttle also where started with a belt.
