The Gear and closest cam lobe are one piece. they then key index and stack on the end lobe, as needed for the intended layout. The gear tooth pitch
afaik does not allow for "perfect" timing in both directions, with several of them swapping I/E functions to boot.
Good enough is what they settle for, itt seems.
Proven by how well they run
