Jeti MFC-2085 and Jeti Setup Question
The MFC-2085 takes one Aileron input and mixes it to two Aileron inputs. Jeti setup only allows a 2 aileron/servo option. Flap is ok because Jeti allows a one flap option.
Will the use of the 2 aileron option cause mixing errors?
Better How did you wire yours or did you bypass the MFC?
Thank you
